ok, i restated how i asked... would u know whats the wattage on each speaker is?marlin29311 wrote:Hmm...the Bose system is about 268 watts....the non-bose would probably be somewhere lower around the 200 mark I would imagine...
What are you looking for this information for? IE, what are you planning on doing with said speakers?Mattv609 wrote:
where do you get these numbers from? BOSE doesn't release its specs on its car audio equipment...marlin29311 wrote:Hmm...the Bose system is about 268 watts....the non-bose would probably be somewhere lower around the 200 mark I would imagine...
Not recommended. Like Doc said above, I doubt there's more than about 10-15 watts per channel going to those speakers. Blowing them would be far too easy. Additionally, you wont gain much by amping the stock paper speakers. You'd be better served by spending the money you have now on upgrading the speakers, then save up and get an amp for the aftermarket speakers later. Amping the paper speakers with their little magnets will not end well.Mattv609 wrote:i want to put a AMP on my interior stock speakers, but dont want to blow them and hook up a mono on a sub....
I built the box myself. There weren't any custom boxes on the market that suited my needs, so I fiberglassed one up myself (cheaper than paying a shop hundreds to do it). Any reputable car audio shop could definitely build something similar (and in all fairness probably do a better job - that was my first time working with fiberglass).Mattv609 wrote:and by the way where u get that Sub box?? u get it custom made??
I've seen those figures before, but I question their accuracy. Also, there is no mention of that being RMS wattage or peak wattage (judging by Bose's history - if that is where Nissan got the numbers from - my guess would be peak wattage). I almost wish I still had a Bose system somewhat handy so I could test the ACTUAL output.marlin29311 wrote:I can't find the original link I had on this, but I found another...
http://nissan-me.com/English/P...r.htm
Click on the Bose Audio System - it says its 264 watts.
http://www.motortrend.com/road....html
Motortrend says 264 too - so I was off a little...
Most of the other Bose systems in Nissan cars are at that 265 mark as well - my guess is instead of having multiple systems, nissan just takes economies of scale and throws the same on in each car.
Gain setting tutorial from my FAQdangeris wrote:Hey Apple, How does one measure the true wattage?..RMS and Peak?
