Don't confuse increased color temperature with increased lumens. In fact, lumens decrease with increasing color temperature over 5600°K. White is your freind, not blue and certainly not purple.StarPD wrote: Book calls for D2S for my car I believe. I suspect that they are 4300k, and that both 5000k and 6500k would be brighter.
I learned this from finding a web site by a vendor that sells HID conversion kits after I posted this. Apparently 6000k won't give me more light.maxnix wrote:Don't confuse increased color temperature with increased lumens. In fact, lumens decrease with increasing color temperature over 5600°K. White is your freind, not blue and certainly not purple.
???maxnix wrote:http://www.sylvania.com/Consum...s.htm
9005su
Nothing legal will approach aircraft landing lighs.
Thanks.Went there, and learned that the high beam bulb is a 9005, and that standard output is 1700 lumens. They don't show anything brighter.
Okay, I did some research. I think the 9005 is an H3 bulb.I also found a source for high output halogen bulbs.StarPD wrote:
Now I just gotta find something with around 2500 to 3000.
Why would one want to install a bulb that gives 25% less illumination?marksport wrote:For 6000K, go with Phillips Ultinon 85126WX. They are rated at 2400 Lumens compared to the factory 85122 Capsule 4300K with 3200 Lumens.....For the low beams, you can get an HID kit with an H1 base. Kits come with it's own wiring harness
The 6000K 85126WX is a D2S capsule and was for the low beam being that it's made by Philips.maxnix wrote:Why would one want to install a bulb that gives 25% less illumination?
The low beam is HID, no need to convert to H1 halogen base.
I thought the high beam bulb on F50s, particularly the 2004 up, is an H3 bulb.marksport wrote:
The H1 as seen in the picture above is installed in the high beam and provided much more illumination than anything else ever did. Even during the daytime, it is so bright that you can barely look at it without hurting your eyes. And it has the correct focal point/cutoff.
The factory low beam are all HID and is a D2S capsule . The 8512### is the Philips part number for the D2S capsules. This particular part 85126WX is the Philips Ultinon Capsule rated at 6000K. The bulb that came with our cars from the factory is the 85122 rated at 4300K.StarPD wrote:I thought the high beam bulb on F50s, particularly the 2004 up, is an H3 bulb.
And You know what you mean, but your comments regarding two different lights, high and low beams in the same paragraph, isn't quite clear, to me at least.
Are you saying that the 85126WX is the low beam and the H1 bulb is the high beam, and that BOTH are brighter than OEM? And which specific HID kit are you referring to? Does that change the high beam from a conventional halogen to HID? Or am I wrong in thinking that the OEM high beam has only a conventional halogen bulb?
The 85126WX has a lower lumen rating but a higher Kelvin rating, so it appears brighter. In other words, the higher the color rating, the more it becomes UV or closer to it.StarPD wrote:And like maxnix, I fail to see how a lower lumen rating, 2400 for the 85126WX vs 3200 for OEM, could be brighter.
Other way around, the HID low beam is rated for 3200 lumens and the high beam is about 1700 lumens. The low beam projectors were designed to illuminate a wide area in front of our cars, making the most of the available light. The high beam is more concentrated and longer range.StarPD wrote:Further, my research reveals that the OEM bulb has 1700 lumens, not 3600.
Am I confusing the high beam at 1700 lumens with a low beam rating of 3600 lumens? I did check it out, and now can't remember which one was 1700 lumens, but I know that one of them is.
Please explain and clarify.
Thanks.
You have to remove the headlight assembly to get to the bulbs. This requires pulling the bumper and grill off, and likely the wheel well covers. Once the headlight is out, you need to grind some of the high beam socket out with a rotary tool like a dremel. The picture that I have posted was incorrect. I have corrected the capsule and the return wire is on the top. With my setup, I bought a capsule that had an H1 base and wire that extended to a D2 style connector. I use Hella ballast packs and built my own wiring harness. Factory high beam wiring triggers the relay that powers up the high beam HID. If you buy a complete kit, many are cheap but normally have warranty, and they come complete with new wiring harness. It's hard to choose a kit due to the cheap pricing, but many kits cost 1/3 of what many reputable online companies sell it for. I bought my 3000K HID conversion kit for my fog lights and it's doing well. Also, one of my high beam capsules was damaged in shipping, and were replaced under warranty.StarPD wrote:Okay, got it.
I know quite a bit about older lighting issues, but little about the newer HID/Xenon equipment.
I think I'd like to consider the high beam HID conversion.Is it hard to get at and remove the old bulb and install the new setup?
Do you have a recommendation for which kit to get? Is it a complete kit, or will I need to buy different wiring harnesses and get ballasts, ignitors, etc? There are a lot of them out there, and suspect that most are cheap Chinee junk.
Thanks.
silver2k2 wrote:It has been well documented that replacing a regular halogen bulb with a HID "retrofit kit" is not effective because the reflector was not designed for the HID bulb arc.
I didn't say that the kits were perfect. They are more effective than the factory halogen on the F50 Q45. Not all headlights are made equal. Like I said earlier, "this is the result of my F50 Q45. A Lexus LS430 or Chevy Cavalier may have different results." I can't even say if you try this in a Y33 or a G50 and you will get as effective results. I have 2 F50 Q45, I will try and do a head to head comparison with the PHILIPS VisionPlus bulbs.silver2k2 wrote:From the articile I posted
From time to time, I am asked to comment on what are marketed as "new developments" in HID kits, and those asking sometimes point out to me that these "new developments" might render this article out-of-date, since the copyright date on the article is older than the date of these "new developments". Please understand, marketeers will always be coming up with dazzling new pseudoscience, tempting new hype and sneaky new ways of trying to convince you to buy their stuff. It's what they do. This article will never go out of date, because the problems with HID kits are conceptual problems, not problems of implementation. Therefore, they cannot be overcome by additional research and development, any more than someone could develop a way for you to put on somebody else's eyeglasses and see correctly
Years ago, and I mean a lot of them, Car and Driver did an extensive field testing of a wide variety of autmotive lighting. They had a straight level road with bushes on the side, and were fortunate enough to have a slightly foggy night which allowed good photos of the actual light beams. The reader could see clearly the exact shape and pattern of the light.That test gave me my initiation into auto lights. It was where I first learned about the jet aircraft landing lights. I incorporated those lights, along with others in my cars. I was driving 425 and 435 HP Corvettes and finally a factory L-88 at the time. My job took me all over the Midwest, and I drove at night, frequently running 135 to 150 MPH for long stretches, sometimes as much as 330 miles at a time. It was imperative to have good lights at that speed, so I made it a point to have the best I could get. Ever since, lighting has been one of the most important features on my cars, all of which have been VERY fast. Tires are another of my favored subjects, and I've become quite sensitive to all aspects of tire evaluation.silver2k2 wrote:That test would be great
Here is an idea of one you can model it after
http://www.autoexpress.co.uk/p....html
