Specifications for the 350z
Nissan 350z / Nissan 370z general community discussion forum
PoorManQ45
You guys probably know all this info, but I like how it is all collected together on this site. *Note, probably a re-post.
http://www.nissannews.com/niss...shtml
2003 Nissan 350Z? Specifications
Mechanical Engine
Name VQ35DE
Cam Design DOHC
Orientation Longitudinal
Cylinders / Configuration V6 w/ Continuous Variable Valve Timing Control System (CVTCS) & Molybdenum coated pistons
Block / Head Composition Aluminum/aluminum
Displacement (liters) 3.5L
Horsepower 287 @ 6,200 RPM
Torque (lbs/ft) 274 @ 4,800 RPM
Bore & Stroke (mm) 95.5 & 81.4
Compression Ratio (:1) 10.3
Maximum Engine Speed 6,600 RPM
Induction System Sequential multi-point electronic fuel injection
Valvetrain 4-valves-per-cylinder
Engine Cover Standard
Engine Mounts (3 mounts per vehicle) 2 liquid filled; 1 rubber
Recommended Fuel Premium unleaded
Emissions System Closed loop feedback system w/ 3-way catalyst
Emission Certification Level LEV
Exhaust Dual (single each side)
Electrical
Ignition System Electronic, Nissan Direct Ignition System (NDIS)
Starter 1.4KW Reduction
Alternator 110 Amp.
Battery 12 Volt
Transmission and Drive System
Drive configuration Mid-mounted front-engine / rear wheel drive
Transmission Type 6-speed manual 5-speed auto w/ manual mode
Standard (Base, Enth, Touring 6MT, Track)
Standard (Touring 5AT) Optional (Enth)
Gear Ratio M/T A/T
1st 3.794 3.540
2nd 2.324 2.264
3rd 1.624 1.472
4th 1.271 1.000
5th 1.000 0.834
6th 0.794 N/A
Reverse 3.446 2.370 Final Drive Ratio 3.538 3.357
Drive Shaft Carbon Fiber Reinforced Plastic (CFRP)
Viscous-Limited Slip Differential Standard on all models but Base
Vehicle Dynamic Control Standard on Perf, Touring 6MT and Track models
Brakes
Standard (Standard on all except Track)
Front .
Type Vented Disc, 2 caliper pistons
Rotor size diameter and thickness (in.) 11.65" x .95"
Rear .
Type Vented Disc, single caliper piston
Rotor size diameter and thickness (in.) 11.50" x .63"
Brembo (Standard on Track) ..Front
Type Vented Disc, 4 caliper pistons
Rotor size diameter and thickness (in.) 12.76" x 1.18"
Rear
Rotor size diameter and thickness (in.) 12.68" x .87"
Brake Assist Standard
Brake Control Power-assisted (vacuum)
ABS Standard
Number of Wheels 4
Number of Channels 4
Number of Sensors 4
Electronic Brake force Distribution (EBD) Standard
Parking Brake Hand operated along left side of center console
Steering
Type Engine speed sensitive power rack-and-pinion
Power Assisted Standard
Overall Ratio 15.9
Turns (lock to lock) 2.6
Turning Diameter (curb to curb, in feet) 35.33
Turning Diameter (wall to wall, in feet) 37.27
Steering Wheel
Tilt Telescopic
3-spoke design w/ air bag
Manual
N/A
Suspension
Front Independent multi-link aluminum suspension
Front Strut Tower Bar Standard
Stabilizer Bar Standard
Rear Independent multi-link aluminum suspension
Integrated Strut Tower Brace Standard
Body / Chassis
Type Unibody
Materials (primary) Corrosion resistant and high strength steel
Hood Aluminum
Rear Hatch Steel
Dimensions
Exterior (inches)
Wheelbase 104.3
Overall length 169.6
Overall width 71.5
Overall height 51.9
Tread width
Front 60.4
Rear 60.8
Coefficient of drag (Cd) 0.30/0.29 Track model
Interior (inches)
Head room 38.2
Leg room 42.6
Hip room 53.9
Shoulder room 53.6
Cargo volume
VDA rating 8.3 cubic feet
SAE rating 6.8 cubic feet
Weights
Base 3,188
Enth 3,197
Perf 3,217
Track 3,225
Tour 5AT 3,247
Tour 6MT 3,210
Curb (pounds) 3,239
Weight distribution (%) Front/Rear 53/47
GVWR 3815
Volume (cubic feet)
Passenger compartment 50.5
Cargo 6.8
Total 57.3
Fuel Economy
City AT 19MT 20 HighwayAT 26MT 26
Classification
2-door coupe
PalmerWMD
Car: 2004 350Z
Good job PMQ!
Fred..
Return to “350z / 370z Discussion”
