dborelli »
https://forums.nicoclub.com/dborelli-u30206.html
Sun Jul 24, 2005 8:22 am
My car (93 240sx) has been running like crap (no power) since i bought it a month ago, and from reading the previous posts in the forums here and looking at the work I've done since I bought the car that hasn't fixed the problem, I have pretty much narrowed it down to a cam timing issue. The guy I bought the car from said he did the timing chain, and from seeing the quality of his other work, I figure he probably messed this up too.
So today I set the engine to TDC and pull the valve cover off, and I am greeted by the cam alignment shown in the attachment. This looks obviously wrong to me from some of the pictures I've seen on the boards. My thought is that I need to turn the intake cam one tooth counterclockwise, which would make the cylinder 1 lobes point away from each other.
The reason I'm posting this is because I'd like a second opinion before I do something that could potentially bend valves. I've never had to work on an interference engine before, and I don't want to make the "new engine" kind of mistake. So what does everyone/anyone think about the proposed solution? You guys have been great with helping me get this car going, and now I need your help to actually make it run well.
And I know the engine is filthy. That's what I get for living in Maine.
Thanks,
Danato
