Specific parts for J30 HU upgrade
Post all your Nissan electronics, car audio and stereo questions here!
robmcole
Car: 93 J30
Could someone please send me a link to which converter I would need to run my JVC HU (LX3 Kameleon) on the existing bose speaker/amp setup. The plan would be to replace the speakers down the road, but for now, this is all I can afford to do. I need the list of 3 parts.
Let me start by saying that my head unit has preouts for all 4 channels (RCA style), are there any that use this or are all these converters High level converters?
1) Wiring harness, not just just the speakers, but power, antenna (actuate the power antenna). All to get the HU working.*Do these include whats necessary to signal needed to actuate the bose amps on?
2) Mounting Kit (I cant seem to find ANYTHING for sale to install a aftermarket HU [single DIN w/ a tray or something] in a Infinti J30)
* I have seen sometimes 3 different converters for sale, I need a link or a model number so I get the correct one.
Again, this is for a 1993 Infiniti J30
-Robert Cole
Simmsled
Car: TSI GTI - E46 325i
http://www.sounddomain.com/sku/PERNISAH4that is the Bose system adaptor 55 bucks
the install is an ISO-DIN install... meaning the brackets in the car attach right to your cd unit... and you need:
antenna adaptorMetra NI-4011
the wire harness you need is thisMetra 70-7550
KNOCK YOURSELF OUT!!!!! GOOD LUCK!!!
robmcole
Car: 93 J30
Do you think there is any difference with this unit you talk about, and the Soundgate OEM4A? I think the one you pointed out I saw at CircuitCity tonight for about $44. I saw that Tweeter (local store) carries the other recommended converter made by Soundgate called the OEM4A. It sells on the internet for around $59-79. I am wondering if it is a better unit or if it really matters. -Robert Cole
Simmsled
soundgate is great stuff. i have used them before in installs. either one will work perfectly.
NY94J30
Car: 2000 Q45 AE
And you'll need a pocket to fill the double din gap that you should be able to find at any place that does installs.
I ran the bose speakers wired to Kenwood headunit for a while - the sound wasnt amazing but it was just as good as the Bose and better than anything I've heard stock beside some of the Lexus Nakamichi, and Mark Levinsons.
