specific dimensions of the VG engine and transmission
Discuss topics related to the VG and VE series engines.
themadscientist
I need to know a couple of measurements please.
transmission total length, from engine mating surface to tailshaft.
distance from engine mating surface to centerpoint of the shifter.
distance from engine mating surface to crossmember studs on busshing.
motor mount position, from transmission mating surface to plane of mounting studs.
motor mount spread across from stud to stud.
engine height from motor mount to topmost point.
engine maximum width, the span of the widest of the engine wherever it is.
best guess at the weight of the engine and transmission combo.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Which transmission?
themadscientist
both if you have it
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Well...there's more than two. There are a 4 speed auto and 5 speed manual for the transverse configuration, and a 4 speed auto and a 5 m/t for the rear-drive config. I think I have diagrams for the auto transverse...I might be able to find the others, but I'm not sure.
themadscientist
just the manual boxes.
RMiller
Car: BBQing
http://forums.freshalloy.com/u...48080I posted this earlier and either someone deleted it or it was never added. Well, if it's gone again I guess I'll know it was deleted. If it was deleted, I can't imagine why since the creator probably has all the dimensions you need. Good luck with whatever.
Return to “VG30 / VE30 Forum”
