"Special" timing chain?! Doesnt have colored links....
Shaefer Thomas
Car: 1992 240sx
Yeah so, Im putting my engine back together today and Im getting wierded out. Im following the FSM, and noticing that I dont have these colored links on my timing chain.... what the hell?! I have ONE, count em, ONE silver link on the chain, that is IT. Now, I marked the 2 links where they met up with the mating marks on the cam gears, and if I put the ONE silver link that I have on the mating mark on the crank gear, the other 2 that I marked dont line up. WTH should I do? Just put the silver one on the crank and go from there or use the 2 marks that I made as a reference?? Im confused...and I really dont want to mess anything up.
Shaefer Thomas
Car: 1992 240sx
man, not alot of people on today huh?
I also must say prior to having my engine running...again. I appreciate all of you very much. The internet is a wonderful thing, but it would be nothing without people who are as helpful, and knowledgeable as most of you.
ILikeMy240sx
Car: SR Power
if you dont have marks, you pretty much have to count as shown.
That sucks that you dont have marks.
This equates to 2 chalupas.
Shaefer Thomas
Car: 1992 240sx
yeah I dunno wtf is up with the no marks thing. Luckily I marked it before I took it off so I should be good.
baja or supreme? beef, chicken, steak?
Shaefer Thomas
Car: 1992 240sx
Uhhh noob question but... is red RTV good enough to use on the front cover and upper and lower oilpan??
Shaefer Thomas
Car: 1992 240sx
bump for answer to noob question.....
ILikeMy240sx
Car: SR Power
I hate those red RTVs. I personally prefer the black ones for any place that requires RTV gaskets. Ive found the black one to be the most consistant and not as prone to leaking as red or blue ones.
Steak baja please.
This is the kind I like.http://www.autobarn.net/per82180.html
but yea red ones will do.
superDorifto
Car: 1997 Eclipse Spyder - AWD/5spd swap in progress
1995 Q45 - 5spd swap in progress
1984 200sx hatch(KA-t swap) - 355WHP
1991/1993/1995/1997 240s - Dead
1982 200sx hatch - fixed/scrapped
Shaefer Thomas wrote:Uhhh noob question but... is red RTV good enough to use on the front cover and upper and lower oilpan??
my grandma uses RTV to hold her dentures in....but seriously, it should be, i used RTV to put my KA together, just make sure you follow the directions and let it cure before you assemble everything.
Geno750
ILikeMy240sx wrote:I hate those red RTVs. I personally prefer the black ones for any place that requires RTV gaskets. Ive found the black one to be the most consistant and not as prone to leaking as red or blue ones.
Steak baja please.
Like he said, use black if you can. I and many other gixxer guys use it to join the engine cases on our bikes, and I used it on my oilpan in the sr20 and haven't seen any hint of a leak.
superDorifto
just make sure you let it cure a bit before you join the two halves (follow the directions!!!)....not that it will leak persay, but it just makes for a better gasket. I didnt on my lower cover, and i had a little bit of wetting after a few hundred miles of driving...
Shaefer Thomas
Car: 1992 240sx
You guys rock. I swear if I come into some money, you all are getting a vacation.
superDorifto
Shaefer Thomas wrote:You guys rock. I swear if I come into some money, you all are getting a vacation.
Just spread the love...if you know the answer to a simple question somewhere down the line....instead of flaming, help out. Its what nico does....
