Special Occasion for lubrication ....
uvamosk
Hey, I have a Ka24de Oil Pump with around 170,000 miles im building a 400WHP Ka24de-t Do you know if i should just get it rebuilt or buy a new one ? and if so how much would a normal rebuild run and what kinda places do them... ?
Thanks guys
Florida240sx
For a car that is goign to have that much power.Go buy a new one. Do you really want to be in the middle of a race or long trip and be thinking that everything is safe EXCEPT the rebuilt oil pump, on whether or not every screw is tight
uvamosk
I went to advance auto and they wanted 225$ for it is there a better place to buy it from... Im dont want to buy something that will have a high chance of going bad on me
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
I have seen them go on eBay for ~150.
180sx
MAXIMA/280zx pump will flow more. But if you instal an oil pressure gage u can tell what shape urs is in based on readings. Also rebuilding is a s good as new , but generally if u change oil on time etc ur pump will outlive ut motor without a problem
uvamosk
MAXIMA/280zx pump? Do they bolt in directly ? if so then ill go that way ... Thanks for letting me in on that advice
uvamosk
^ BUMP ^
uvamosk
BUMP AGAIN
Chezedik
Car: 1991 Nissan 240sx
Not on DOHC, but they do on SOHC. Also, 225 is a pretty good deal. When I was working at Adnace they were 375 and not available. Make sure that you are getting the right one. Because there is a huge difference between the two pumps. Like that the DOHC pump is the entire front timing cover. You buy it as a set, and it is driven by the snout on the crank. I have seen some nice high volume units at a similar price (will try to get a link later) and since they are not driven off the distributor like a SBC, there is no need for brass distributor gears or special shear pins. Also, will not hurt the life of any components, just cost you a little power.
Titan
http://www.drivewire.com/nissa....html
OEM SOHC Oil Pump.
$67.62
Just bought mine from there.
uvamosk
IM DOHC
WDRacing
You can raise the oil pressure of the pump yourself. You add a washer/shim underthe spring inside the pump which increases the spring tension therefore increasing the oil pressure. It's somthing done alot on the Skyline GTR do to oiling issues once you get to any decent horespower or increased RPM.
WD
uvamosk
Thanks for Advice then I guess ill buy stock pump and do that thing...
Thanks
