2002 Maxima 6speed with SPEC-V trans
tater02
Car: 2002 Maxima 6speed
Just wondering what all needs to be done to swap a 2006 spec-v manual transmission into a 2002 Maxima 6 speed? The reason I ask is because the input shaft bearing on my 02 maxima went. I have been looking for used transmission(car-parts.com) but all used maxima trans from 02up are at least $800, locking/non diff. Used spec-v transmissions are about half the cost plus most have lsd too. I heard sentra owners have done the swap when puttin a 3.5 in the sentra, wondering if any maxima owners have done the same process.
-I know the bellhousing need to be switched. I have the bellhouseing separated from my maxima trans case. How do you disassemble the gear set from the existing maxima bellhousing with the spec-v gear set? Is it hard?
-Speedometer, is it needed, if so how do you connect it?\
RFS6F51H ('05 & '06 Maxima)
3rd gear double-cone synchronizer
1st & 2nd triple-cone synchronizer
RFS6F51H ('04 Maxima):
1st double-cone synchronizer
RFS6F51H ('02 & '03 Maxima):
1st & 2nd double-cone synchronizer
RFS6F51H (04-06 Sentra):
RFS6F51H (02-03 Sentra)
Any help would be greatly appreciated. Thank you
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO.
You can find overhaul instructions for the trans starting on page AT-283 of the FSM. http://www.nicoclub.com/FSM/maxima/2002/AT.pdf
Not sure about the speedometer.
Just wondering...why are you using the Spec V trans (I'm guessing the gearing)?
tater02
The input shaft bearing my 02 maxima broke so I need to repair the transmission. The reason why I chose a spec-v trans is because of price and lsd. Spec-v used manual trans run about $400-600 cheaper then maxima trans. Also, I have found alot more spec-v trans with less mileage then maxima trans.
maxhopper
Interesting. Please keep us updated.
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
I didnt think the spec V would fit into a 2k2 6mt. I could be wrong cause i have no done it. The 6mt max did come with a LSD as well.
tater02
I bought a used 06 spec v trans with only 27000 miles (car-parts.com) and swapped the sentra bellhousing with the maxima bellhousing. My friend switched the bellhousings, because both transmissions have the gear-sets mounted in the bellhousing, which requires some internal transmission skills to remove/install. I have pictures, but not sure how to insert them. Anyway, I should have the trans installed this weekend.
Total cost <600 :yesnod ; trans and bellhousing switch
advantages: LSD, extra synchro in 2nd gear
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
You'll have to host them through photobucket or a similar program. Lets seem some pictures!
tater02
Project is done. It is possible to use a sentra transmission with a maxima bellhousing in a 2002 maxima 6 spd. Also, fidanza flywheel and 350z clutch works great with this setup.
Fezzik
Awesome find tater. Good job. Post some pics of the install, and a writeup if you can.
tmakt
Yes, you can use a Spec-V transmission for your maxima. You just need the maxima LSD bellhousing. part number: 30400-8H810.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
So the LSD bell is different than the open bell? How bad was it swapping everything over?
tater02
I'm not sure if the open and lsd bell are different. I used the original bell from my 2002 Maxima SE which was a open diff. I had the transmission in for 8000 miles now, no problems.
I had a friend who did the swap. He has experience with working on manual transmissions. It took him 5 hours to complete and about $170 to do.
I could probably do the swap myself, by using the information from nico repair manual (to get all the clearances right); but I was in school at the time.
