Spec V SER motor in a Versa?
xtremeversa
Car: 2007 Nissan Versa Hatchback
I have a 2007 Versa with the same 1.8 engine as the 2007 Sentra. I don't want to build an engine that produces appx 100hp lol. So I was wondering if I could put a spec v SER motor in here. Same as the 1.8 engines except a little bigger, right? Should bolt right up?
I posted this on the Versa forum, but they are all boring lol. "Why you wanna change the engine? What about gas mileage? You don't want your warranty?" Lol. Help me out guys!!!!
WDRacing
Do they share the same transmission?
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
check the parts numbers if they match might be do able,however custom swaps always has surprises good and bad,so be ready for a few headaches
xtremeversa
Same trans numbers. The 2.0 Sentra has the same engine numbers and letters, but the spec v SER motor is different. Could that hurt me any?
jbracy7
I will fit,but with custom mounts,unpin repin ecu, or custom tuning and fwd swaps are easy
Noxy
Car: 1993 Nissan 240SX
1992 NX2000
2004 Sentra Spec V
There are two models of QR25's for Spec V's. The one from B16 2007+ Sentras will not even fit in our B15's without major modification, because practically everything was changed. If you were to attempt a QR swap you'd probably have an easier time with the first gen engines from 2002-2006. Then again, if the Versa engine bay is as small as I remember it being, you'd have an easier time stuffing a bear into a marshmallow...
Honestly, The QRs are decent engines, but not worth the headache you'll get. I would turbocharge the QG if you really want the power, I've seen more than a few that surprised me haha.
