Spec Request:
mitcheyismyname
Im sorry if this a repost. I tried searching but didnt come up with anything. Discount tire direct has a bunch of setups on this wheel
Anyway i know those wheels are MB Weapons. Does anyone have any info the specs of this cars setup? It seems to look like 18's. More pics of this car would be great.
And if anyone has a pic of these in 17's or 18's Bronze with the 15 offset on a s13 (coupe preferably)......
AZ89two4Tsx
Looks to be about 9" wide with a 10-15 offset. He's running a bit of camber in the back and has a slight pull. The front looks the same so he may have a spacer on the back?
They look good on an s13/s14. Just look for other wheels with the same size/offset. If you already like the style just see if they have the offsets you like. Elite(s) wheels are 17x9 +15 so you could kinda get the idea of fitment if you look through the Elite wheel threads.
240lookis
Car: 1990 240sx hatch
those are the most aggressive sized 17's, so like 17x9 +15, with like 15 or 20mm spacers
mitcheyismyname
Thanks for your help guys. Now...i did some searching...discount tire direct seems to be the cheapest available.
Any other suggestions for prices?
mRodiek
Car: Stock Hatch
it looks like the only way your getting 17x9 is if youve got 5lugsi hope you did a 5lug swap
mitcheyismyname
DriftBoy07 wrote:it looks like the only way your getting 17x9 is if youve got 5lugsi hope you did a 5lug swap
Ill be ordering the 5 lug swap same time i order wheels
