S14-NEO »
https://forums.nicoclub.com/s14-neo-u25945.html
Thu Sep 29, 2005 1:51 pm
man i am not sure if i am the olny one out there who is having problems with this clutch setup but I AM!! I have had numerous issues with this setup, first one was when i was down at moroso for a racing event (which i did NOT participate). I was leaving the track when i had to pull out in traffic, in order to keep from spinning really badly i engaged the clutched softly and the damn disc stuck to the flywheel. it was a loooong 70mile trip home to say the least seems how i had a very hard time shifitng gears and ended up hurting my transmission in the process. then shorlty after that i started hearing a roaring noise (throwout bearing) about a week after that. I called and spoke to the spec TECH dude and he says he is aware of the problem with the compound of the disc causing it to stick and he is also aware of the roaring noise coming fromt he throwout bearing. when i got the car home from the track i had to park it until i had time to remove the transmission and unstick the disc. which when the transmission is removed is quite simple.just give it a good blow with a soft mallet and she comes right off. so i cleaned it off and reinstalled it and has been fine for the past month and a half or so. UNTIL TONIGHT!! . It has done it yet again. this freaking crap is getting old FAST. I am going to call spec again tommorrow and see if they will ship me out another setup so i can get my car mobile again and ill ship this one back to them so they can look it over. I have been told that they have very good customer service...WE"LL SEE!! I just wanted to see if anyone else out there has had similar instances.
Mark
