spec clutch????????
smokeshow11
Car: 2002 spec v
hay out there in nissan land looking 4 a clutch 4 my 02 spec v.and anything anyone knows that will help make up my mind. looking 4 a soft push,nice daily driving clutch but one that will take a *** kicking. thanks yall.......
nametakennow
Car: '06 MINI Cooper S
Your stock one can take plenty of beating, especially at stock or near-stock power.
If you want a stock feel with better wear, get a kevlar disc and use your stock pressure plate, but it's honestly not really worth your time unless the clutch is dead and/or you're making much higher power than stock.
smokeshow11
Car: 2002 spec v
thanks 4 the info,this is the deal my car drops down 2 like 500 rpms when i get on the clutch. it also makes a huming noise when i am taking off at a slow speed till the clutch is disingaged(sorry 4 the spelling).so i think it is gone!!!! ,,,,,,,,but i also think my sinkrows are out of wack also becouse it has a clunk-clunk feel shifting gears......i just need 2 take it 2 a shop but i like working on cars myself. this is my first import that i am trying 2 make a real street/track car into it has a good base i just have 2 build it up a little and now this problem....any help would be sweet... thanks bro johnny
nametakennow
Hmmm...
Alright, well the humming would be your clutch slipping because you're slipping into gear. If you just dumped the clutch into first you'd get a clean thud.
If your clutch is dying, you can tell by smacking the gas in the middle of the powerband and seeing if the clutch slips. If it does, you need a new one.
I like a somewhat clunky shifter, personally, it lets you know you got into gear correctly. If your syncros go, you will have a hell of a time downshifting. Check that before assuming they're dead. '02 QR trannies are prone to failure, so it's possible.
smokeshow11
Car: 2002 spec v
well that suxs doesnt sound good, ,well hope it isnt a bad tran,well how can i fix the sinkrows(?),i was going to put in a short trow b&m shifter in it does that sound like a bad idea?thanks 4 all the info
nametakennow
A shortshifter is always a good investment, IMO.
Only way to fix syncros is to replace them.
You could get some better transmission oil, like a Redline synthetic, and that would smooth out shifts. I bet you're syncros are fine though, at this point, unless you beat the hell out of the transmission and/or don't know how to downshift properly.
Is your car still under warranty? If so, Nissan should replace your transmission if it fails, just make sure to show up to the dealership without the short shifter if that happens.
