spec 2 or 3 clutch
vboyq
hey everyone, i was wondering which do u guys think i would need for this setup
s13 sr20detFULL exhaust from o2 housing back(straight no cat)greddy vspecgreddy airinx intakewalbro pumpz32 fuel fliterhot pipe w/ HKS SSQVstock t25@ 7psi but will go to 14Koyo Radiator(aluminum)
so far this is what i have accumulated i was wodering if u think i should do the spec 2 or a 6 puck spec 3.. i hear people say they have no daily driving problems with the 3. i was also wondering how long the spec 2 would last over the spec 3 w daily driving, some dragging, and a little autox/ attempted drifting( :) )
DriftS14
I have the SPEC 2 and the mods listed in my sig and it has yet to slip. (knock, knock, knock :) ) Either the car bogs or boils the tires when I drag launch. Daily driving is excellent.
vboyq
yes but i am wondering if i am overkilling with the spec 3...btw wats ur time in t he 1/4 drifts14?
candela
Get a stage 3 if youa re sure you are gettgin a spec clutch (though i don't like them). Trust me...
DriftS14
I had a six puck in my KA and didn't like the drivability at all. It chattered and made noises all the time. But no, I don't think it's overkill to get one, I just wanted a more streetable disc. I haven't gone to the track yet, and when I do it will be an 1/8 mile, that's all they have here. I can g-tech a 13.6 at 111 all day long with a 5.3 0-60, and I have a best of 13.54 at 112. I guess it depends on how much you believe in the almighty g-tech. :)
My best ever with my KA was a 15.4 at 94
dj_lennon_franz
Car: 1992 240sx
6 puck on a stock pressure plate is a good mix...it wont kill yer driveline and it will take the abuse of clutch kicking (drift) or heavy shifting (drag)..also it one make one leg horrendiously larger than the other from hittin the clutch pedal =)
vboyq
well its a kit so its the spec 3 clutch kit with a HD pressure platehere this is the one in case ur wondering:http://w1.igateway.com/clients...=form
oh and keep the responsed coming, especially those w/ a spec 3!
vboyq
o btw i need it to be streetable also i.e. DAILY DRIVER.. this is not a weekend or track car this is my "everyday i gotta go to school, hang out, and get groceries" carso keep that in mind
vboyq
cmon anyone i need more input, i don't want a clutch thats gonna be too stif if i can get the stage 2
dj_lennon_franz
Car: 1992 240sx
if u keep yer stock pressure plate it wont be unbearable..the clutch itself will be a little grabby but it wont affect the clutch pedal to drastically
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I hate my Spec II! It slips at the track all the time during hard launches (I do 2.0 60ft's with open diff). I can only imagine what it looks like with not even 8k miles on it.
f150intally
ItzGenX,have you had your car dynoed? Your mods are very similar to mine as well as your track numbers.
Just curious
vboyq
hey itzgenx so r u saying that u would rather have a spec 3, or no spec at all?
also dj lennon, if i use the heavy duty pressure plate in the kit, the pedal will feel alot heavier?
dj_lennon_franz
Car: 1992 240sx
yes....the plate affects the way yer clutch pedal feels...keep yer stock one to keep yer ride comfort
DriftS14
The pressure plates in the spec 2 and spec 3 kits are the same. The torque holding increase is in the disc. My clutch feel is nearly identical to stock.
vboyq
o i c
DriftS14
IMHO, I wish I would have gotten a stage 3. I wasn't expecting to upgrade as much as I have and will. I'm sure the stage 2 will crap out soon. Hope that helps.
vboyq
well thanks everyone for the input i guess ima stay wtih the spec 3
ItzGenX
Dyno run on a mustang dyno was 257hp 273ft/lb @ 1bar uncorrected in 50 degree weather. I did the track run at 12.5psi. As for the Spec question, I would rather not go Spec at all because of my bad encounter with the stage II (even if stage III would work better). First impressions are sometimes the only impressions if its a bad one. I was not impressed even before I got to drive on the clutch because even after installation, the pedal feel felt SOFTER then stock. Next on the list to try is a ACT 6 puck.
f150intally
ItzGenX wrote:Dyno run on a mustang dyno was 257hp 273ft/lb @ 1bar uncorrected in 50 degree weather.
You running stock cams? My sr with almost exactly the same mods made 244.2, also on a mustang dyno. I also noticed you rebuilt your motor. Are you running stock compression?
vboyq
hmm... now i wonder about my purchase..
civics91
Car: cars,cars,cars
i drive with a spec stage 3 almost every day its not too bad at all
vboyq
its defintiely not stock feel thought rite?i don't really care as long as its not "big left leg" heavy
civics91
Car: cars,cars,cars
it feels stock to me and the stock clutch in my 200sx is harder than my spec stage 3
240dreams
Car: 240's
link may help with your questions: http://www.nissaninfiniticlub....57447
unfrgivn
I run a spec3 as a daily driver and it's fine. It feels nice and responsive, not harsh.
My next clutch will be a full-face disc though cause I'm worried that my 6-puck will go out on me anyday. When they go, they just go. There is no slipping.
vboyq
wat mods do u have that u would be worried about it going... similar to my list up top?
pissedoffsol
Car: Honda's, Turbos, Skylines... not necessarliy in that order
spec clutches suck. get an ACT if you want something that will actually hold and still be drivable every day
silva180sx1515
how long are the stage 3 clutch predicted to last?
TS4L
Car: 1989 Nissan 240sx w/Sr20DET
My stage III sucked it only lasted about 6000 miles and it just slips all the time I am putting in a ACT
