Theoretically Speaking...?
Shalz92
Car: Nissan 300ZX TT '94
Hello everyone! I have question that is straight to the point. How much WHP do you think i will be able to make with the following MODS:
CAR: 300ZX TT 1994
MILEAGE: Approx. 84,000 Miles
TURBO: Z1 GT525
DOWNPIPE: Specialty Z 3" Downpipe
SPARK PLUGS: NGK Iridium IX Spark Plugs VG30DETT (HEAT RANGE 7)
INTERCOOLER: CXRACING FMIC
ECU: NISTUNE
METHANOL INJECTION SYSTEM: AEM WATER/METHANOL INJECTION
BOOST CONTROLLER: GFB Geforce II
EXHAUST: TESTPIPE ALL THE WAY
AIR INTAKE: DUAL POP FOAM INTAKE
Im just kind of anxious to see what kind of power the car will be making. I'm getting all mods installed this week and tune done....would love to hear your opinions and estimate of what kind of power to the wheels im looking at. Thank you!
Shalz92
****ALSO****
INJECTOR: JECS High Performance Fuel Injectors 555CC
centralcoaster33
Car: 1997 Nissan 240SX #5
This is like counting the number of jelly beans in a jar. The number could easily be give or take 50 for a swing of 100 in error. So the only point of this would be to get as close as you can to the real number with your guessed number. Usually the prize is the jar of the jelly beans. Without a prize for getting as close as I can, why guess? Where's my motivation? :gotme
You made a plan, saved up, coordinated the parts and labor. You waited this long and it sounds like you just have a week more to go. Why not wait for real numbers? :ohno:
PS - I am excited for you. :bigthumb: Is your car there being worked on now? Will it be done by the weekend? Will you be driving it hard right away or will it need a break in period for a few miles first?
fastVG30DETT
Car: Z32
Low 4s on pump. What kind of clutch?
Shalz92
centralcoaster33 wrote:
Mon Aug 28, 2017 9:47 am
Its still being worked on and doubt i will get back by the weekend...i dont think i will be driving it hard right away and even when i get it back i wont be able too...i have to wait to make a appointment with Z Car garage in San Jose for a proper tune. Thank you for the well wishes...im really excited but mostly anxious and inpatient lol.
Shalz92
fastVG30DETT wrote:
Tue Aug 29, 2017 5:16 am
Its an automatic....i know i know i know i know..."WHAT ARE YOU THINKING".....lol. Dont worry before the car gets on the road and starts to being pushed and tuned its transmission is getting an upgrade.
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
I have a similar setup, only I have 2.5 full exhaust, 740 injectors, single intake, and bigger turbos than yours, and I'm in the low 400s at around 17lbs of boost.
I also have a built autobox. You gotta get it built as soon as you can, or swap to a 5spd. You'll lose your 4th, then 3rd pretty quick if you do hard hwy pulls. Not to worry you, just a forewarning.
centralcoaster33
Cool man! I've been to Z-car garage and talked with them there and at Laguna Seca. Lot's of good know how in that company.
Shalz92
zxFarside wrote:
Tue Aug 29, 2017 1:05 pm
So what exactly did you get done for the gear box? Can you send me links to the parts? Thx.
NolimitZ32
zxFarside, What turbos are you running? low 400s seems kind of low to me on discos (i'm assuming you are running discos or some variation thereof). Does the slushbox rob that much?
zxFarside
03 Suburban 5.3
00 BMW 323
Shalz92 wrote:
Fri Sep 01, 2017 8:19 am
I don't really have a parts list. I had a local trans guy that built it for me. Its got upgraded clutch packs, stronger bands, shift kit, and a fresh valve body. I also had the planetary bearing caps welded to prevent the big kaboom. All the cooler lines were redone as well, and bumped in diameter, with a 25k btu cooler. Higher stall converter, you can get those here: http://converter.com/dragon.htm
I know Z1 and Specialty Z both sell a upgraded trany. That my be easier and more direct than my route.
NolimitZ32 wrote:
Fri Sep 01, 2017 9:07 am
Yeah its a couple potatos.
Autos do eat up a lot of power. I also have a single intake, and a pretty rich tune. Thinking back, it may also have been only 15lbs, I'm not sure though. I just had it thrown on the dyno at work on a slow day, to see what it was making, and that was before I build the trans. I'll have to get in on there again to get some actual data haha.
