Speakers
R50-D
Car: 2004 Pathfinder LE 4WD black/black
One of my front speakers is blown. From the pictures I have seen the speakers look like cheap quality cardboard cones. I am planning to change both the front and rear speakers with these: http://www.futureshop.ca/en-CA/product/ ... aa265ben02
I am leaving the amps intact. Can anyone tell me if these fit on the amp/speaker holder and inside the doors? The Bose speakers are 1 ohm if I am not mistaking, and therefore the subs are made for speakers with 1 ohm impedance. Will I lose a lot of volume by switching to the 4 ohm speakers? Thanks!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Those should fit fine.
I think for best results you should get a new head unit and bypass the Bose amps, either by running your own speaker wire to each door or by hacking up the wiring a little to bypass the amps.
