speakers going out
q45_owner
Car: 92 Q45 w/TCS
Hey, I've noticed for about six months that my speakers are acting up. When I hit a bump one or both of my front speakers go out, but now its been stuck that way. Anyone know what the problem is and how much it'll cost to get fixed? Thanks
Bwana
Car: Denali
Not sure, but it sounds like a loose connection to me. If that's all it is you should be able to fix it yourself, if you can find it. If there's internal problems with your speakers you can send 'em to one of the places that repairs Bose speakers. Or better yet, you can send 'em in to Bose and for $75 a speaker they'll put a new cone and amp on 'em for ya. That was the price for the rears in my Q but I think fronts were the same price. Great deal in my opinion, makes 'em good as new.
q45_owner
Car: 92 Q45 w/TCS
thanks for the advice... but also I need advice about repairing my sun visor. I remember searching for it on this board someone had a solution to reattaching the piece awhile ago.
I think the big thread on that issue was created or answered by Tangalora. If you find it, please post it here!
-Jesda
Rex
Car: None
Here's the thread on the the speakers.
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
Does Bose replace them with new "paper" cones?
How does the 10Yr+ design hold up (sound wise) when compaired to newer speakers?
GreenQ45a
Good thing they sit on the other side of the car over there.
another view
metaverse3
Sounds like a loose connection. Could also be your bose amps..relay connection etc. etc. Me, personally, that is a blessing to replace the bose system... Blow the thing with a shotgun.. Crappy amps with 2nd grade soldering and leaky capacitors.. Coffee paper cone speakers.. Line driven system with 1amp speakers which won't work with anything else but bose.. Ripoff repair centers that resolder surface mount resistors that "magically" fix display issues... Spent half my life with Nissan/infiniti cars dealing with bose issues.. Liberating them is an art unto itself.. Good luck.
GreenQ45a
metaverse3,
What do you recommend for a good replacement?
I want something independant of the Bose headunit.
I was thinking Boston Pro's.
metaverse3
Funny you should ask. I just put a Pioneer Nav Sys 910 navigation unit in my wife's Infiniti J30 yesterday. For a ton of naysayers who said it would not work, it works, and sounds as good if not better than the factory bose. If your amps/speakers are fine and the headunit is kaput, buy a headunit that has RCA pre-amp outputs. Fuse them into the harness (buy a metra harness..quality) make sure you connect the amp turn on wire..very critical since it turns on the bose amps to give you sound.
If you're looking for speaker replacements, go with your budget. I'm not a speaker expert, but some price conscious and decent speakers seem to be audiobahn, pioneer TSA line. kenwood KFC components..etc. I've never been impressed with Boston Pro's.. Heard them in cars and when they bastardized the home PC speaker line with gateway PC's.. If you want to splurge a bit, go with focal's. Very impressive and quality oriented.. Greate soundstage..and their warranty service seems to be up to speed in case you need it... Bear in mind that Bose has special speaker sizes that no man makes.. 4.5" doors.. 6.75" rears etc etc.. You have to rig them to make them work.. Don't even waste your money with PIE adapters that convert bose systems to aftermarket headunits..Totally useless..and just plain ineffective. If you go with an aftermarket headunit..go with rca pre-outs.. If you are going to replace the speakers, run new wiring to each door, or, if you are good with circuit diagrams, there is a way to bypass the bose amps and still use the factory wiring with aftermarket speakers. I recall doing it in my maxima....sorry, no Q45 experience. Good luck..
GreenQ45a
Any Pictures?
metaverse3
lol. I will get pictures next week. check this space.. hold me to it..!!! BTW, don't go with a pioneer nav unless you pay $300+ for the updated maps..it does not even have my street address and I'm a 7year old neighborhood and pioneer claims the map data was from 2003
PoorManQ45
I would suggest scraping the Bose Amps completely. In there place, you could install an amp capable of 2 Ohms, and use that to power both of the speakers in series (they're 1 Ohm each, right?).
TheColoradoQ wrote:Not sure, but it sounds like a loose connection to me. If that's all it is you should be able to fix it yourself, if you can find it. If there's internal problems with your speakers you can send 'em to one of the places that repairs Bose speakers. Or better yet, you can send 'em in to Bose and for $75 a speaker they'll put a new cone and amp on 'em for ya. That was the price for the rears in my Q but I think fronts were the same price. Great deal in my opinion, makes 'em good as new.
For $75 a speaker, you could buy a cheap amp (50W RMS x 2) and a descent set of 3-way or Coaxial speakers. This would really make the Bose/Clarion HU shine.
q45_owner
Car: 92 Q45 w/TCS
Here's the sunvisor link if anyone else needs it:
http://www.nicoclub.com/zerothread?id=39096
