phuphyter »
https://forums.nicoclub.com/phuphyter-u19167.html
Sat Dec 17, 2005 5:13 pm
PMQ, hopefully you can help me with this.
Background:As you know I just got a new headunit (Eclipse 7301) installed and it worked perfectly fine. It has a history of to blowing its internal amp, which puts out 16 watts rms. I received it as a hand-me-down gift so I can deal with that one flaw. I also upgraded the front speakers to a cheap pair of 6x8 2-way pioneers which are rated at 40- 50 watts rms. I noticed that when I turn it up all the way (just to test things out) I either hear distortion or clipping I don't know how to tell the difference. Or is it the amp that clips and causes the sound from the speakers to distort? I don't know. Anyways...
Problem:Everything was working fine for the week it was installed. Last night I turned on the radio and no sound. I turned it off then back on and then problem solved. Later that night I had it turned up pretty loud more than 3/4 volume) because well, I thought the speakers could take it, that the hu could put out a clean enough signal, and I was on the freeway and I like my music loud. I didn't hear any distortion/clipping of the signal at anytime, but then suddenly no sound. They just quit.
Now I'm pretty damn sure its the internal amp, but I'm not totally positive. Since the rear speakers (not stock. don't know the specs since i didn't upgrade them or use them) were still working, I spliced the rear speaker wires from the hu to the fronts...No sounds, just a hint distortion coming from the left speaker. I then reconnected the rears and they played fine.
So now I'm wondering if its the internal amp that's blown or are the front speakers gone because I supplied them with too little power and asked too much from them. Can it be both?
