jyoxthimer »
https://forums.nicoclub.com/jyoxthimer-u123353.html
Tue Dec 30, 2008 5:25 pm
Hello. I just installed an after market radio with steering wheel controls and Sirius Satellite service. I found this post about speaker wire colors and I am stumped. I have everything ready to go except this. My original harness places all the speaker wires together and there are 9 of them. I have the basic factory harness (no BOSE) and here are my colors. Black/Red, Green/Gray, Brown/Blue, White/Blue, Yellow/Green, Yellow/Blue, and Gray. I am so stuck because none of these colors match anything this forum has posted. HELP. I called the dealership and those idiots don't even know how to put in a different radio.
Update: Okay...the 20 pin factory connector doesn't need to be touched in any way as long as you use the wire harness adapter. I was stuck on the black wire which is traditionally ground in a DC system. Apparently this is also a speaker wire. I ran a separate black wire directly to the chassis and then attached all ground-needed wires to this. It worked perfectly. PAC sells the steering wheel control module that does in fact need to tap into the factory harness but PAC's website has the correct colors for the pin#. I still have not found any resource that correctly identifies the factory wire harness colors.
Installed: Kenwood DDX512 with Sirius Satellite Radio and I bypassed the parking brake wire to watch DVD's (in the passenger seat) into a 2008 Nissan Altima Coupe....and I'm a girl!
Modified by jyoxthimer at 8:13 PM 1/1/2009
Modified by jyoxthimer at 8:15 PM 1/1/2009
