Some questions:
What are you putting this in?
What is you budget for amps?
Are the speakers Single Voice or Coil Dual Voice Coil?
If I was you I would use the four 8" and sell the 10". You have more surface area for bass but you have to get a custom box to hold them.
As for amp power, you have two factors, the RMS rating, and Dual Voice Coil (4 Ohm x 2 from you post if they are DVC).
Max power you will need: 200 x 4 = 800 watts.
JL Audio has good wire digrams for sub connections of different voice coil types.
http://mobile.jlaudio.com/supp...d=145
Once you find out about voice coil type chose the right diagram.
The amp I think needs to be able to handle a 1000w at 2 Ohms RMS at least (a litte more than need is always good) and try to invest into a good amp.
My picks:
MTX TA Super ampsAutoTek Mean Machine series mono ampsHiFonics mono ampsRockford Fosgate BD amps
