Ive never heard of them, so Id say no they are not decent. You hear certain names because they are good speakers. The nobody brands tend to be that way for a reason.jjcuff1 wrote:Is Arc Audio KAR speakers decent?
jjcuff1 wrote:Yeah I figured as much. Well Arc Audio supposedly makes killer amps. they have high SQ I googled it. So I figure the other stuff was similar. Yeah I will bail and shop around so for SURE if I keep stock amp I should definitely have 92+DB speakers and 2ohm
BUT what if I get bored with stock bose amp and want to upgrade to simple 4channel for speakers and I have 2 ohm speakers arent 4ch-2 ohm stable amps more money? What if I go with 4ohm 93db speaker and granted have less power or just crank up more for now?
Then what about sub? I was thinking an enclosure not needed too much? can I just swap in a 10" and get line outs and go to an amp off the existing sub connector? I hear the bose also doesn't something with the sub signal that might require a separate EQ processor as well as part of the Line Out conversion?
Ah pushing, pulling, 210, 220, whatever it takesjjcuff1 wrote:Well I am confused by what you said "Pushing a 4ohms to a 2 ohm speaker") The impedance is not pushed it is the mechanical function of the speaker design itself not the amp pushing it. But I do understand that an amp must be capable of running at 2 ohms. The lower the resistance the higher the current load the speaker will pull and therefore overheat the amp if it is not capable of being '2 Ohm stable"
Now with the Bose it is a 2 ohm amp, good, but concern was putting in a 4ohm speaker would not hurt the amp at all it will actually draw less current which is good BUT it will also half the power output so maybe only 8 vs 16 wattsOn top of that if you have an inefficient speaker say under 92db you are already have to crank speaker up just to get the volume output and then you will start clipping.
So I went ahead and ordered infinity 60.9CS kappa components for the fronts at 95DB and 2 ohms and the na 6032SI shallow mounts for the rears at 93db and 2 ohms
I will run the stock amp for now and then have shop install line out and arc audio amp and 10" sub with custom enclosure in rear deck
jjcuff1 wrote:Well I am confused by what you said "Pushing a 4ohms to a 2 ohm speaker")...So I went ahead and ordered infinity 60.9CS kappa components for the fronts at 95DB and 2 ohms and the na 6032SI shallow mounts for the rears at 93db and 2 ohms...
jjcuff1 wrote:Update:
Well Here is what I just installed
Infinity Kappa 60.9CS 2 ohm components up front
Shallow mount 6.5" infinity reference in the back doors...
