speaker help
Post all your Nissan electronics, car audio and stereo questions here!
240sx_in_209
Car: 89 240sx.... 93 coupe
hey guys well i ended up buys a set of phoenix gold component speakers. they are rms-50 and max-200 but in the instruction it has a pic of an amp connected to them. Does that mean that i need to run an amp to them or is it just in the pictures?
Crazyirish
Car: Nothing noteworthy at the moment...
A discrete amplifier will pretty much always sound better than running the speakers off your head unit, but you should still be able to do it without any problems.
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
Crazyirish wrote:A discrete amplifier will pretty much always sound better than running the speakers off your head unit, but you should still be able to do it without any problems.
The man speaks the truth.
It also might be possible, depending on your crossover, to bi-amp your components with your headunit if you're not running, or not needing to run rear speakers.
