speaker doesnt work
Post all your Nissan electronics, car audio and stereo questions here!
Kouki_Dan
Car: 1998 Nissan 240sx SE
I just bought a 98 240sx and the driver side speaker doesn't work, they are aftermarket speakers. I'd like some troubleshooting tips.
Thanks
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Check the wiring behind the radio and in the trunk where the amp was. If those are fine, then pull the door panel and make sure the connections on the back of the speaker are good.
Kouki_Dan
ok thanks
audtatious
You can check the speaker itself using a AA battery and touching the speakers +/- leads to the battery. Should make the speaker "pop". If the speaker does not move then the voice coil is frozen up and you should replace them.
