Possibly. It depends on the size of the amps. If you're putting a sub in both corners of the trunk, you'll have about the same amount of space left over as I had for my one sub amp. My Sundown 3000D is a pretty big amp (roughly 24" by 10"):srwong wrote:wow, that is a tight fit.... do you think there would be enough room to keep spare and still fit 2 amps flush with trunk?
It goes to the sheet metal floor of the trunk. I had to remove the bluetooth/xm modules from their mounting points. They are tucked away on the side to maintain steering wheel button function. Here's a shot before fiberglassing started (should be easier to see the base of the sub enclosure):Infantry1327 wrote:Apple I can't really tell. does your sub box go all the way down to the trunk floor. Or does it go on top of the floor you built?
i am going to do fiberglass. it just seems more logical to go that route. Not exactly sure when I'm going to start on this. I still want to think of some designs before I actually start it.Infantry1327 wrote:So have you decided which route u are going to go?
Good idea. Plan it all out. Once you get into it you wont want to start over. It will probably be a large time commitment, but I think you'll be very happy in the long run.srwong wrote:
yea, i don't wanna be halfway in it and be like "omg i should try this" and end up f***ing it up or something... i wanna have everything planned out, then when i'm ready i'll just bust all that s*** out.... =)AppleBonker wrote:Good idea. Plan it all out. Once you get into it you wont want to start over. It will probably be a large time commitment, but I think you'll be very happy in the long run.
i'm going to do two 10'sCoupeguy23 wrote:Hey srwong are you just doing one 10 or 2 10s
