Malbec 56 Beast wrote: ↑Sat Feb 15, 2020 6:08 pm
So can we just replace the rear speakers only, leave the rest of the stereo alone. Even with the system off it does that damn noise and I want it to go away.
In going that I can get a replacement and have it function without the rattle. Any help would be appreciated. If I missed the info regarding this sorry.
Does polk, alpine or anyone else make one for us.
Andy
Unfortunately you can't replace one element and expect things to be normal. Bose speakers have a weird impedance at <2 Ohms but uses extremely efficient speakers that get loud with very little wattage (10 nominal - 40 peak, actual figures)
Not many aftermarket companies make 2 Ohm car speakers and the ones that do will not match the efficiency of the factory speaker. You may barely notice they're playing if at all. Also, one thing I've noticed is that Bose factory speaker mounts rarely fit other manufacturer's speaker mounts so you may be looking at custom brackets as well.
Not sure if you've taken the door panel off yet but I'd inspect first before making any decisions. It might be something simple that's causing the rattle.
