ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Fri Oct 22, 2004 11:34 am
1996 Nissan 240sx 77k miles
I got a check engine light for the spd sensor... Of course spdometer worked on and off so I got a new sensor and a new gear... Installed them.
As soon as I started the car the speedometer stayed zero until 4th gear. It worked for a while then it went to zero for a split second then worked for a while then dropped to zero and stayed there...
I pulled the engine code and spd sensor was not one of them...
If I wanted to check the harness that connects to the spd sensor, do I check for continuity or resistance? how?
Thank you.
