SPC control arm question.
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
I'm one step from buying this thing and completing my suspension, I'm just real hesitant about something down there being adjustable so I wanted to do research. Through my research I came across this, http://www.myg37.com/forums/brakes-and- ... attle.html
So does this happen to anyone with these control arm on their M? Do your spc control arm bottom out and hit the inside wheel well?
EniGmA1987
Car: '06 Infiniti M35 Sport
Seems like a lot of those people have a problem with the arms hitting the fender well. Eibach also makes some adjustable control arms, but some people have squeaking issues with the Eibach's. The only reason to get control arms with more adjustment range is if you are going pretty low, if you are not dropping low on Coilovers or air then you can probably be ok on stock control arms. So if you are looking to get new ones, just buy stock. You already know they work well.
TDot
My purpose is mostly asthetics, I hate wheels that slant...even a little. I like perfectly straight wheels that are flush with the fender. I don't like the camber. The rear I may be able to get away with since it will only drop .5", but the front will be 1.5" and I think the camber will be noticeable. Or no? I have the tein H. Doesnt spc make the eibachs? I thought they were just rebranded. So wouldn't that mean the spc squeak? How long ago was this happening?
