sparkplugs
02pathy
just wanted to know how hard it is for 1 to change the plugs on a 02 pathylooks to me like the throttle body has to be removed. n e 1 out there with ne tricks or advice
Here's a good start - http://www.nicoclub.com/FSM/pathfinder/2001/
Hopefully a Pathy owner will pop in with more info.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
I just had mine replaced last week, by the dealer. I'm glad I did.From everything I've read and heard, it's a pain in the ***. Unless you are patient and have good tools, you may want to let the pros do it.How many Kms (miles) is on your engine, by the way?
Axelpkt
Car: 2002 Nissan Pathfinder 5spd
I did mine myself and I didn't think it was that bad. The only really annoying part was taking off the throttle body. But over all it wasn't the worst ones I've done.
fsugatorbait
Car: 11 EX Journey
How long should the stock plugs last? I've got about 72k miles on an 01 QX and wondering if I should look into changing them out.
Buzzman
Mine had 164K Kms on it. That's just over 100k miles.The old plugs still looked good.The truck was actually running fine before I changed them. I did it 'cause I thought it was time.
02pathy
i was reading the service guide yesterday n to my understanding it said 168km, but best way to determine is to take out one of the easy ones and inspect it the color wear n tear
Pathfinder995
Car: 99.5 Nissan Pathfinder SE
you have to remove the throttle body on the VQ to do the plugs? man i thought doing plugs on the VG was a pain--that's insane!
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
my manual said 96k kms? im at 104k and was worried i was overdue, but i guess not eh?
Issac
Car: 2002 Pathfinder, 1995 Q45
My 2002 had 92k miles on them. They still had 10 to 20k more life for sure.They were in great shape. It is not hard to change them. You do have to be organized, use anti seize and dielectic grease.NGK is the way to go.Carefully remove and replace, making sure to thread properly.Clean as you go.
The throttle body is not hard, and you pull a hose or two but no big, then some allen key bolts,and there are lots of little hoses and clips. I zip tied some of the hoses, wires out of the way gently.
You will want to replace the gasket on TB to intake manifold, or maybe rtv and the old one if you have to.
The bonus is you get a clean TB from both sides.Make sure coil pack sits down well on spark plug and don't overtighten the little 10mm bolt that holds it down.
If you have time and a few tools, you can do it yourself if you are just systematic and not foolish. It is not something that is as hard as it sounds.Also the longer you go, the harder it can become to remove old plugs.No special tool like the 3.3 and they are all about the same effort. But it is not a 1 hour job. More like 2 for the first time.
sackett13
Car: 2001 pathfinder
i just changed mine on my 01.it is not a real hard job.the throttle body has to be moved aside.other then that 3 brackets,all you nees is a 10 mm socket and your spark plug socket.
