sparkplugs smelling like fuel ugh
dark240kid
Car: 240sx
ok so my 92 nissan 240sx has been running crappy lately. it's been hesitating a lot been getting worse. About a week ago i took out the fuel rail checked for a leaky injector didn't see anything. one of the injectors was alittle wet,but not leaking im not sure if that might have been the problem or what. Anyways today i check the sparkplugs, and they all smell like gas..any idea what may be wrong?? help! :wtf2:
dark240kid
Car: 240sx
i also forgot to add when i start the car. if i don't give it gas the car will shut off. sometimes i won't have to though
Hoffman5982
Car: '95 sr20det 240sx
might be an injector that's stuck open. That's what happened with my sr when I swapped it in
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I agree is it one plug or all?
dark240kid
Car: 240sx
its all of the spark plugs that smell like gas. i even did the test where you unplug each injector to see which one might be bad and not make a difference in the idle and they all seemed fine.
zsmizzy
Car: 1993 nissan 240sx s13 hatch DOHC KA24DE
get a noid light test done. injectors might be getting a bad pulse from the ecu. if thats the case, new ecu or a reflash if possible should fix it. also check your wires to each injector for frays, splits, open etc.
dark240kid
Car: 240sx
ok i'll look into that. i also checked for codes i got code 34 then i got 55..i know 34 is knock sensor but then 55 means nothing is wrong??
samxini
Car: '95 240sx w/Kouki conversion
A bad knock sensor can defenetly make your car run rough, clear the code and see if the light comes on again.
Knock sensors are a pain to replace and way to expensive unless you can find a used one.
dark240kid
Car: 240sx
i know this is old, but i still haven't pin point the problem. i just pulled my o2 senor it doesn't look to good can this be the problem?? also idk if i mentioned but the car will shut off if i don't give it gas
LoserCard
Car: Forest Green 1993 240SX SE Fastback
That can most definitely be the problem, I recommend doing a full tune up. Replace plugs, cap, rotor, o2, and clean your MAF and air filter (replace if necessary). Replace the knock sensor as well, it will retard your timing, thus create more unburnt fuel.
