Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Mar 20, 2007 2:31 pm
I was referring to magnified observation of electrotrodes and actual measurements of gap, and measured power balance numbers..................lack of a misfire is so far removed from the definition of a suitable plug. The oem coil on plug system will fire a plug almost without electrodes at normal rpm...........things get dicey above 6,500 rpms.
187k is just getting broken in if oil and air filters are replaced at frequent intervals.
It seems that even with the finest care that 250k starts the decline......really a function of the number of cold starts [below ~~ 50F] and the time for lubricity to ramp up to functioning oil.
