Spark problem or iono?
alnissan
Car: 93 Ford Ranger 4x4
92 Nissan 240SX SE coupe
Ok hi guys my new(to me) 92 coupe isn't running right, the fourth cylinder isnt firing. I checked the spark plug and replaced it with no difference. I switched the 3rd and 4th plug wires and no difference. I can take the plug out when it is running and it makes no difference. I haven't checked compression yet but what do u guys think?
sportzguy38
Car: 240sx
Most likely its the injector its a common problem with the 240sx. To make sure what you can do is switch the injector from cylinder 4 with the injector from another cylinder and see if the problem changes to the other cylinder.
alnissan
Thanks ill try tomorrow maybe and see if that works. Ive searched for this prob but couldn't find anything 'bout it.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Nah, you don't even need to check. I can guarentee its an injector.
This is a common problem. Happened to me to
