tony602 »
https://forums.nicoclub.com/tony602-u206189.html
Tue Jul 31, 2012 12:51 am
Hi! im new to these forums so you can take my word with a grain of sand. But i would like to enlighten people on some basic and fundamental laws of physics that may help you.
Copper is by far the best conductive metal of them all. It's more conductive than platnum, iridium and any other metal they build spark plugs out off. Which means that copper spark plugs deliver more electrons and thus a bigger hotter spark. If you have a stock engine you will make the most HP and burn the fuel more compleatly if you go with copper plugs.
However, copper fouls a lot faster so if you have a turbo or use nitrous then you will need harder metals so you don't change plugs every weekend. That's why people use harder metals in spark plugs. but if you have a stock engine regular cheap V-power NGK plugs will give you the most compleate burn. Just my 2 cents.
Cheers!
