Spark plugs
merlinq2
Car: 2007 Infiniti M35x
Does anyone know if the spark plugs for a 3.5 liter maxima will fit the 07 M35. The cost of the infiniti plugs is out rageious
Ilya
Just get NGK Iridium or Platinum plugs from your local parts store. As long as they are NGK, you'll be fine. You can even go with copper, which fire the best, but don't last as long as the more expensive ones.
Nissan's/Infiniti's don't work good with any other plug but NGK...so make sure they are NGK.
merlinq2
Thanks
I was thinking about using a non iridium plug and replacing them once every two years. I will head over to the parts store and see what I can find
Happen to know the part number for n g k copper
Ilya
I know for the Maxima it was like B5KRE-11 or something.
szh
Car: 2018 Tesla Model 3.
IlyaKol wrote:Nissan's/Infiniti's don't work good with any other plug but NGK...so make sure they are NGK.
Exactly right! :yesnod
Z
JDMlove
Car: 2006 M35X
2007 HR 350Z
IlyaKol wrote:Just get NGK Iridium or Platinum plugs from your local parts store. As long as they are NGK, you'll be fine. You can even go with copper, which fire the best, but don't last as long as the more expensive ones.
NGK Iridium one step colder? or same heat as stock?
usually they advise to put one step colder.
