+1Poyzinous wrote:Unless you have serious Mods, you don't need to go colder. And few plugs work better than the factory ones, part number #22401-5M015
They aren't difficult, but they aren't easy either. You need to remove the intake plenum. And if you find oil leaking in the tube, time for new valve covers and gaskets.
To change the spark plugs?? I didn't. Just loosened the harness cause it's in the way.Poyzinous wrote:You need to remove the intake plenum.
Your head was clouded with thoughts of home cooked, eastern style NC BBQ!!!!Poyzinous wrote:I meant to say intake tubing.... but whatever.
I have the box and it doesn't say. I looked hereca18detgabby wrote:if the valve cover gaskets need to be replaced, I will be letting warranty handle it.
my fiance's 6 requires removal of a s*** ton of stuff, this is cake walk in comparison. My CA only required the removal of about 20 bolts.... so it is a tad harder than that.
I have talked with one of my parts suppliers and they have a hook up at HKS for spark plugs, so I might step out from NGK, but thinking I will stick to my NGKs for now.
are stockers platinum? or irdium?
stock plugs are plats, i looked in manual today thinking they might actually tell you plug gap in there..........Poyzinous wrote:iridium. and I've seen numerous persons get non ngk plugs, only to not like how they act and get ngk plugs anyway. just sayin.
Does the newer G's have the bolt holding in the transmission fluid dip stick with a sticker on top saying "take to dealership for service" on it? I found that hilarious on my aunt's G35.ca18detgabby wrote:stock plugs are plats, i looked in manual today thinking they might actually tell you plug gap in there..........Poyzinous wrote:iridium. and I've seen numerous persons get non ngk plugs, only to not like how they act and get ngk plugs anyway. just sayin.
it says take it to a dealer for service![]()
think I will go with Iridiums as they are always pre-gapped and rock it. I have to wait for the HKS stuff to get here, so eh I will still with something I get get at advance and know will work well.
