jamm220 »
https://forums.nicoclub.com/jamm220-u139398.html
Sun Mar 28, 2010 3:11 am
im not sure but last summer i picked up a cheap 02 Q45 for 5k with 180k miles on it. First thing i did was change the oil, transmission fluid, air filter, diff fluid and the plugs (used Denso) before doing my research. Im not sure if it was the plugs are not but the car was running mint before i switch the plugs but after the engine had a knock on cylinder 8. After i removed the plug i cold see where piston was hitting have no idea why if they were to long or not. I torque them to the correct specs also...morale of story i guess its true not to use denso plugs in the Q45
