king_johnthegreat »
https://forums.nicoclub.com/king-johnthegreat-u2837.html
Fri Aug 22, 2003 11:01 am
If you have, or are planning on getting an aftermarket ignition system, you might want to consider using common steel or copper plugs. Precious metal plugs will degrade at much higher rates with increased gap/discharge voltage common to high power aftermarket systems. If you are running stock ignition, you might consider the NGK Iridium. At any rate, you should go one heat range colder, and experiment with gapping proportional to the spark power of your system.John
