Actually the plug's reach will be the same. Colder plugs just have the insulating ceramic nose attach to the metal thread shell closer to the electrode. This allows a more direct heat transfer path out of the plug into the cylinder head. By contrast, a hotter plug has a ceramic nose that attaches deeper inside the shell which limits heat transfer some.rn79870 wrote:If I remember correctly, one of the differences in heat range is the reach of the electrode into the cylinder. The further the reach, the hotter the plug. One step colder should cause no real problem.
I'd bet money your iridium plugs only have an iridium center electrode with a nickel ground. As the G35 has a distributorless ignition system, expect the ground electrodes to wear prematurely.cweberj30t wrote:You could go with the colder plugs and not hurt anything. I found Iridiums from Advance auto for $6.99 a plug. The funny thing is they had them on there for $12.99 as well. I guess it was a mistake on their part, but I got them for $6.99. I must say I am very happy with the Iridiums. Seems to idle smoother, shift better at high rpms.
NGK Iridium IX's. Sorry I wasn't more clear on that. I wouldn't use anything but NGK period.C-Kwik wrote:
I'd use the NGK double platinums over the Iridium IX's though.cweberj30t wrote:NGK Iridium IX's. Sorry I wasn't more clear on that. I wouldn't use anything but NGK period.
cweberj30t wrote:Check it out. The part number 4469 is $6.99 and the part number LFR5AIX11 is $12.99. Same plug, NGK Iridium IX. Just thought I would pass the savings on to other NICO members.
http://www.partsamerica.com/Pr...Plugs
