Spark Plugs
AJRK
Car: 2001 QX4 4x4, 2003 Jaguar XJR, 2014 Cadillac ATS 2.0T 6MT
Its almost time for me to replace the spark plugs in my '01 QX4. It has 92,000KM on it (about 57,000mi). I believe the owners manual reccomends replacing them at about 96,000Km (60,000mi). I plan to replace them with platinum tipped plugs like OEM, but I will probably have it done at an independent shop I use frequently. Does anyone have any advice on what brand to use? Also, if the car is going to be sitting for a few months come fall, is it better to replace them before, or after?
Thanks in advance.
SayNoToPistons
OEM or NGK... I only use those.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I just ordered OEM from infinitipartsusa 8.25 each.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
OEM's are made by NGK. They are the best choice so stick with what works as for when to change them it makes little difference.
6T9_CHARGER_RT
Anyone try the Iridium plugs from NGK?
Fenris
Car: 2011 Subaru WRX
1989 Nissan 240SX
i did (NGK Iridium IX's)... in my 240sx... its got the KA truck motor so that counts right? It runs so much smoother and better than the Bosch Plat +4s the previous owner used
