Spark plugs
8ggalant
Car: nissan cefiro
Hey everyone...i looked in the FAQ and didnt quite find my answer....
for the ngk's...its states pfr6a-11...thats kool..but they will need to be special ordered... a few lines down it says "pfr6/bcpr6" , well i went and bought teh bcpr6's but the part # says BCPR6ES-11....can i use this plug...if not where did you all get your plugs from?/ thanks...my plugs are black as night and they're really worn down so that MIGHT have a little to do w/ my smoking...i need to go drive this thing and see what up w/ it
THanks in advance
kevin
pulsar gtr
Car: NISSAN VEHICLES
If you can't get what you want, just go to your auto store and ask for some platnium plugs for a 1988 nissan pulsar with ca18de engine, they are the same.
PULSAR GTRRafi
8ggalant
Car: nissan cefiro
well id rather stay away from "platinum" plugs...i just need to know if these are the right bcpr6's ...i appreciate the help tho rafi
sdtouge
Car: 1990 240sx coupe
why would you want to stay away from platinum?
because they extrememly expensive or because they do wont or something?
pulsar gtr
Personally, I love the platinum, but as sdtouge said, they are a bit more expensive, but I believe they are well worth to have them.
I am not sure about the part # though,Front experince, I have seen platinum on DSM eagle talon and the car ran like ****, had to install the stock type back on and car runs awesome, very common on dsm eagle talon,
PULSAR GTRRafi
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I was always conditioned to never use platinum plugs on a turbo car. Stick with the cheap copper NGKs.
sdtouge
how come?
8ggalant
Car: nissan cefiro
when i was in japan my friend put sum kinda of platinum plugs on his 180 and it ran like shyt...put the ngk's back on and it ran like a charm ...i mean he even checked tha gaping and everything the car just DID NOT like those plugs lol....so thats why...(i also have witnessed the problem on dsm's)...has nothing to do w/ price tho
crazymax
Car: 89 coupe
Im using the S12 1.8 turbo exhaust side plugs, works fine to me. I think they are the BCPR6ES-11...
sdtouge
so you guys get the de or the et plugs, and from a 88?
i still dont underwatnd why it would run like crap wit the plantinum. there still ngk, just better, i though plaitunm or iriduim are suppost to be the "shizzle"
so are you guys recomending just normal ngk ones, just standard ones?
radmar1
Car: 91 mr2, 01 galant, and trying to get a 240
i stick with the basic copper ones, i used to have a talon tsi, and the platinum plugs did make it run like crap, i dont know why but ever since then i have been staying away from them
burnout 180
Car: 1990 s13 180sx ca18det
Spark plugs
CA18DET NGK PFR6A-11 This is an original platinum tip and resistor type plug and is fine for standard boost, should never need changing. Gap is set to 1.1mm
SR20DET NGK PFR6B-9 This is an original platinum tip and resistor type plug and is fine for standard boost, should never need changing. Gap is set to 0.9mm
NGK BCP6ES-11 or BCP7ES-11 ( colder ) A normal type non resistor plug, better with high boost. It has the same temperature rating, thread and reach as the above. The resistor type plugs can apparently misfire at high boost. Change at 40,000km intervals. Set gap to 1.0mm
RMiller
Car: BBQing
I have a set of BCPR6ES-11 and a set of BCPR7ES-11 and at .9 bar w/ a t28 the colder plugs are required. I get hesitation with the hotter (6) plugs. Screw the platinum and iridium plugs, they cost like 10X more.
