Q_SHIP wrote:Easy job. give yourself an hour, a plug socket, a few different size extensions, and a needle nose.
Did you do them on your G50?
Ive done the plugs 4 times I think, most recently on Rex's Q (with TCS). TCS makes it miserable on the drivers side because thers so much crap you have to remove. The allens are tough to get to, an allen socket that you can put on a socket wrench might be nice... Cant remember what size they are..
Once you get the crap off the plastic covers off and remove the plastic covers, and then remove the coil packs, its not hard. Basically theres just a bunch of little easy jobs that add up to a pain.
Certainly this would not be something id pay someone to do, unless you have more money then patience. Thats all it takes, is patience. Best thing to do is take your time (like I did) and spend an afternoon doing it.
The plug job is a really easy job, just takes time.
You dont have to reset the ECU or anything after you mess wtih it, if you want to feel better about it [placebo] unplug the battery and the ECU will be reset when you plug it back in. Unplugging the battery is good practice anyway.
