QFourFive »
https://forums.nicoclub.com/qfourfive-u134315.html
Mon Sep 07, 2009 12:05 pm
I know that NGK Platinum sparks plugs are recommended for the y33, but as i was searching spark plugs I read the description for the NGK Iridium IX spark plugs, and they sounded like they would help my car perform better.
Info on the Platinum:NGK G-POWER PLATINUM SERIES SPARK PLUG, SOLD INDIVIDUALLY -- 14 mm thread, 19 mm reach,16 mm hex size, gasket seat, resistor, solid terminal, JIS height, projected tip, platinum tipped center electrode, trapezoid beveled cut ground electrode, 1.016 mm gap, heat range 5; The best platinum spark plug at an economical cost; Features fine platinum tip that reduces required voltage; Provides faster starts and quicker acceleration; Extremely durable under high heat; Trivalent metal plating offers superior anti-corrosion and anti-seizing properties.
Info on the Iridium IX:NGK IRIDIUM IX SERIES SPARK PLUG, SOLD INDIVIDUALLY -- 14 mm thread, 19 mm reach, 16 mm hex size, gasket seat, resistor, solid terminal, ISO length, projected tip, fine wire 0.6 mm iridium center electrode, tapered cut ground electrode, 1.1 mm gap, heat range 5; Designed specifically for the performance enthusiast; Offers extreme ignitability, improved throttle response and superior anti fouling; Iridium alloy has extremely high melting point making it perfect for today's high-tech and high performance engines; Features fine iridium tip that ensures high durability and a consistently stable spark; Trivalent metal plating offers superior anti-corrosion and anti-seizing properties; Delivers outstanding acceleration, high fuel efficiency and durability with its ultimate design, technology and performance.
From Car-Stuff.com
Any info/suggestions will be appreciated.
