Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Wed Mar 17, 2010 2:32 pm
And the '01 will require some disassembly, esp. for the back two plugs on the US driver's side. I've got a 2001 PF and I've done it twice now. I start on the US passenger's side, front to rear, then the US driver's side, front torear. After four plugs, stop and assess your available time. The last two will probably take a bit longer than the first four. If that means another day,no problem.
The coils take a good yank to pull out. Get as far under the coil as you can.Don't even THINK about yanking the wire.
After you pull the coil, blow out the hole with compressed air (canned air would probably work). The '01 isn't nearly as bad as my '87 and '95 were for sand around the plugs (it could be like the Sahara down there) but I've gotten a few grains out on the '01.
Modified by Chuck Tribolet at 5:38 PM 3/17/2010
Chuck Tribolet on Sun Aug 12, 2012 8:42 pm, edited 1 time in total.
