SardarQ wrote:How much torque can the NGK plugs handle prior to breaking? I would think the new plugs would be a little more stronger than the plugs in old cars - about 20 or so years ago?
It's not the plugs, it the threads in the aluminum heads that fail.
I think 28 ft. lbs is the maximum, but check the box.
If you are not very familiar with aluminum, and even if you are, always use lubrication and a torque wrench. The clue is feeling the crush washer compressing. I would estimate that some of the OEM plugs on my wife's VH41DE required in excess of 40 ft. lbs. to loosen.
Hopefully you intalled the correct NGK plugs. If not, yank them and replace.
