Logan76 »
https://forums.nicoclub.com/logan76-u38992.html
Sat Nov 17, 2007 2:28 pm
What plug gap and heat range is best for my set-up, I dont know jack squat about spark plugs, in my CA powered cars I never had to change the heat range because I never was running enough boost out of a big enough turbo. Can I just go to advanced auto and tell them what heat range I want? I read that a gap of 38 is good to start with, give me your insight. my setup will be JGS kit, 550cc injectors, enthalpy tune, z32 maf, and 8lbs of boost, if you need more info I will do my best to provide it, thanks guys.
