dj_lennon_franz wrote:if u want a stiff suspension setup that will be good for autoX and drift...dont waste ur money (not saying that its a waste cause its a good stiff setup for everyday street driving) on the AGX/Tein combo...the teins are very soft springs (.5kg stiffer than stock i think)...just go all out spend the cash on a nice set of Tein Dampers...HEs are recommended for drift as they have been designed PURELY for drifting...it makes the rear end kick out easier due to the dampning rates...if youre interested in buying the AGX/Tein combo ive had mine for less than a year and im selling them for $550 with Cusco camber plates (-10 deg of camber possible)...its a nice stiff setup for learning drift or drag racing on
Umm...the Tein S-Tech's I bought for my AGX's were 3.7 kg/mm. Last I checked, that's more stiff than 2.2 kg/mm (stock) Granted, it's a progressive spring, so that's an ultimal rate, not a constant rate, but this car is my daily driver as well as my track car.
tm_kickz wrote:Where can I find NGK Plugs????Heat range 7
Can I go to a local car parts shop and get it???
http://www.streetracingshop.co....html
Or go to google and search for NGK Iridium. Most auto stores don't carry cool nifty plugs, although I think Autozone is starting to carry them
