replaced the spark plugs. and tryed turning on the ignition and the car still wont start. I checked the ignition wire and im only getting a little bit of spark coming out. It seems like i am not getting enough spark and thats why the car wont start. Could this be an ignition coil problem?srpowered240sx wrote:check your plugs, replace if necessary. get a spark plug tester, and test the wires individually. easy, and they cost about 2 bucks.
Yes its cranking very hard. The battery is fine. Pop start? and yeah i have a 5 speed manual.srpowered240sx wrote:if you have any spark, then the coil is good. is it cranking hard, or slow like the battery might be dead?? id try to pop start it if it is a 5 speed.
I replaced my ignition coil and i seem to be getting a much better spark. But the car is still not turning on. Could it be my ignition wire?srpowered240sx wrote:if you have any spark, then the coil is good. is it cranking hard, or slow like the battery might be dead?? id try to pop start it if it is a 5 speed.
did that with my friends jeep once. Let's just say it hurt.... alotit doesn't just jolt you.. I felt the electricity run up my left arm, across my shoulder blades, and down my right arm. Proceeded to watch it arc 2 inches from my right index finger into his hood. then my back felt like it was on fire, i was very surprised to say the least. But he had his car running better the next day once he had new wires and plugs.edgartheace wrote:easiest and cheapest way to do it, is to grab the wire
Is it possible for the chain to do that? I mean i had the car running for about a week 1/2 and all of a sudden it would just jump a tooth over? and not start anymore?amolao wrote:What the prior history?? Something got replaced??
I was you I check the timing again....trust me, if is off just by one tooth it will not start..... I think your spark is fine.
Ok i went and checked my timing. Does this look okay to you?amolao wrote:What the prior history?? Something got replaced??
