Spark plug wire suggestions?
SloS13
I agree, kind of a ghey question, but what are you KA-T guys runnin? I dont want to spend more than is necessary. Probably going to run 12psi tops on the motor.
Thanks
Dattebayo
You are going to want more fuel (bigger injectors) and spark with 12 psi. I personnally think thats alot especially with stock internals... Get those Nology "hotwires" everyone talks about and the new coil. A couple of the moderators around here said good stuff about them. But theres not really a need for more spark unless you get more fuel.
SloS13
the setup will be walbro 255, 370's, SAFC and wideband o2 setup I'll have a spare motor on hand. treating the stock motor as a learning experience
SloS13
I forgot to add, i already have an MSD6a, coil, and BTM
Xero
I'd say get some sort of 8mm wire and you'll be good to go.
240marcuSX
Car: E34 525i
E46 M3
links to nology hotwires anyone?
"the setup will be walbro 255, 370's, SAFC and wideband o2 setup "
let me know how that^ works out for you. whered you get your 370's??
95_240sx
Car: My baby (car)
SloS13
I think i got the 370's off NICO classifieds if im not mistaken. I always thought those nology wires sounded kinda gimmicky and $150 for some plug wires sounds kinda steep
erich
I've had great results with the NGK wires. the KA-T runs great witht them. I also have a Mallory HyFire 6A (MSD 6A clone) and a MSD blaster SS coil.
red240ne
Car: mmm...donuts
Yea, I got NGK's. Just make sure they don't crossfire, because I've had problems like that.
C-Kwik
My stock wires work just fine.
Nology wires do increase the peak spark energy, but since the total energy is still limited to how quickly the coil can charge, the spark itself has no more energy than stock. It just realeases the spark energy at a much shorter interval. I've heard of cases where it's both made some power and where it actually hurt performance. Optimally, you would want a hotter spark with about the same duration as stock. I have seen some use Nology wires with an MSD and have extremely good results(relative of course). Funny thing was he took it off when he went to sell the car and it ran like crap.
Pornflakes
You may want to think twice about getting Nology wires... Read on the following, and then make your decision:
http://www.magnecor.com/magnecor1/main.htm
Hit "Brief overview..." and "The truth...". Some real good knowledge about ignition wires.
