spark plug wire question
VinceSez
Car: 1992 Nissan 240sx
What does pulling the spark plug wires one at a time while the engine is running technically do?
jh3xp
Car: 1992 240sx SE Coupe
if your rpm's dont drop significantly when u pull one of the spark plug wires then that cylinder isnt firing. Then you have to figure out if its spark or fuel or sumtin
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
jh3xp wrote:if your rpm's dont drop significantly when u pull one of the spark plug wires then that cylinder isnt firing. Then you have to figure out if its spark or fuel or sumtin
word, its just to help narrow a problem down to one of the cylinders.
VinceSez
i see... is this a good way to check if one of your injectors are bad?
pr240sx
If the cable is worn...you will receive a good jolt and probably smack your head to the hood.
