Spark Plug wire order important?
onosqv
Car: '92 240sx Vert
I'm just writing down things I did that may have contributed to my idling problems.
I'm wondering if the spark plug wire order matters?
I currently have the wires hooked up as 1,3,4,2 counter clockwise starting from bottom right on the distributor cap.
The 1,3,4,2 wires are connected in order to the spark plug closest to the inside of the car to the outside/front of car.
Is that the correct order?
Thank you much.
180fan
Car: 89 fastback
match the wires to the cylinders to the markings on the distributor cap. yes the order matters.
DAEDALUS
Car: 1990 Infiniti Q45
If the car ran fine for 5-10 minutes as you stated in the other thread, I would guess your wire order is fine. You would have noticed right away if you were missing 2 or more cylinders!
onosqv
Car: '92 240sx Vert
DAEDALUS wrote:If the car ran fine for 5-10 minutes as you stated in the other thread, I would guess your wire order is fine. You would have noticed right away if you were missing 2 or more cylinders!
Excellent. I just always get paranoid because I tend to forget order number when I take the wires out, I try to write it down, but usually pen and paper aren't around when working on my car.
Thanks.
onosqv
Car: '92 240sx Vert
In Addition regarding wire order:
Would it matter if the order was 1,3,4,2 or 1,2,3,4 as long as I have the corresponding wire to the right cylinder?
Thanks
180fan
Car: 89 fastback
just match the wires to the numbers on the dist cap and you'll be good to go
Big Red
I followed the instructions in the $110 Nissan book and they were wrong, the engine ran like crap (like not at all) and the exhaust stunk , everything else checked out so I compared the book to the Haynes manual and it was different!
I redid the wires and she fired right up!
