babowc »
https://forums.nicoclub.com/babowc-u21423.html
Wed Feb 07, 2007 7:22 pm
Well,since i got all my turbo parts in, i decided to do a quick compression test dry and wet.
i have to say.. they were a bit odd.
First round:take all plug wires off,unplug fuel pump fuse,un screw all plugs.
screw in tester, crank.i held the ignition for what seemed to be 4 full cranks, twice on dry.they all came to 175~180.
Second round:pour little oil, hold ignition one time for full 4 cranks.all within 220.
However, it depended on how much oil I put in as well.I poured a little more oil in one cylinder because I was lazy and didnt get somethign to measure it with.one came out with ~240.
Interesting to say the least, anyone care to chime in about this?
And.. my plugs.
I have the NGK stock replacements, and when i saw it, the tip was white, but all eles was good.Does that mean I was running in lean condition/timing wasnt set correctly/ran too hot?
My motor burns oil, i know that for sure, but if the compression test says its good.. its good, right?
I do plan on replacing the valve seals, whenever they come in
